Operator and instruction manuals (3)
Safety and Compliance Manual (Revision 9) (Multilingual)
Last updated
18/07/2023
Part number: 80669C
Sensor PHC Ecodesign Requirements (Revision 0) (Multilingual)
Last updated
21/04/2021
Part number: 811310MU
Showing 3 of 3 documents
Specifications
Maximum speed | 5120 mm/m (200 ipm) |
Range of motion | 150 mm (6") |
Arc voltage set-point | 50 V – 210 V arc voltage set-point for arc-voltage feedback; accurate to 1 arc-volt |
Ohmic contact and stall-force initial height sense | |
On/off signal provided by CNC | |
Multiple cable options in various lengths available to suit different applications | |
* Information subject to change without notice ** User supplied display and keyboard are required |
Upgrades
Sensor torch height control
Compatible with EDGE® Connect and other CNCs, Sensor® THC is a full-featured torch height control system that can significantly increase the productivity and profitability of your shape cutting operation. Suitable for high definition and conventional plasma applications.
Field service bulletins (4)
Showing 4 of 4 documents
