Powermax45 plasma system
Operator and instruction manuals (6)
Cut with Powermax on an EDGE Connect CNC - Manual Addendum (Revision 1)
Powermax EtherCAT Interface for EDGE Connect Installation and Setup Manual (Revision 2)
Showing 6 of 6 documents
Service manuals (2)
Powermax45 Service Manual – Flashing LED Condition for 480 V CSA Power Supplies
Showing 2 of 2 documents
Specifications
Input voltages (± 10%) |
CSA | 200 – 240 V, 1-PH, 50-60 Hz 480 V, 3-PH, 50-60 Hz |
CE | 230 V, 1-PH, 50-60 Hz 400 V, 3-PH, 50-60 Hz |
Input Current @ 5.95 kW | CSA | 200/230 V, 1-PH, 34/28 A 480 V, 3-PH, 9 A |
CE | 230 V, 1-PH, 30 A 380/400 V, 3-PH, 10.5/10 A |
Output current | 20 - 45 A | |
Rated output voltage | 132 VDC | |
Duty cycle @ 40°C (104°F) | CSA | 50% @ 45 A, 200 – 240 V, 1-PH 60% @ 41 A, 200 – 240 V, 1-PH 100% @ 32 A, 200 – 240 V, 1-PH |
CE | 50% @ 45 A, 230 V, 1-PH 60% @ 41 A, 230 V, 1-PH 100% @ 32 A, 230 V, 1-PH |
CE | 50% @ 45 A, 380/400 V, 3-PH 60% @ 41 A, 380/400 V, 3-PH 100% @ 32 A, 380/400 V, 3-PH |
Open circuit voltage (OCV) | 275 VDC | |
Dimensions with handles | 426 mm (16.75") D; 172 mm (6.75") W; 348 mm (13.7") H |
Weight with 6.1 m (20') torch | CSA | 17 kg (37 lbs) |
CE | 16 kg (35 lbs) | |
Gas Supply | Clean, dry, oil-free air or nitrogen | |
Recommended gas inlet flow rate / pressure |
Cutting: 170 l/min (360 scfh; 6 scfm) @ 80 psi (5.5 bar) Gouging: 360 scfh; 170 l/min (6 scfm) @ 60 psi (4.1 bar) |
Input power cable length | 3 m (10') | |
Power supply type | Inverter - IGBT |
Engine drive rating | System output current | Performance (arc stretch) |
8 kW | 45 A | Full |
6 kW | 45 A | Limited |
6 kW | 30 A | Full |
Cut capacity
Capacity | Thickness | Cut speed |
Cutting |
Recommended | 12 mm (1/2") | 500 mm/min (20 ipm) |
19 mm (3/4") | 250 mm/min (10 ipm) | |
Severance (hand cutting) | 25 mm (1") | 125 mm/min (5 ipm) |
Pierce* | 12 mm (1/2") |
*Pierce rating for handheld use or with automatic torch height control
Capacity | Metal removal rate | Groove profile |
Gouging |
Typical gouge | 2,8 kg/hr (6.2 lbs/hr) | 3,3 mm D x 5,5 mm W (0.13" D x 0.22" W) |
Production cut chart
Material | Thickness | Current | Maximum cut speed * | ||
inches | mm | amps | ipm | mm/min | |
Mild steel | 10 GA | 3 | 45 | 175 | 4445 |
1/4 | 6 | 45 | 75 | 1905 | |
3/8 | 10 | 45 | 40 | 1016 | |
1/2 | 12 | 45 | 25 | 635 | |
3/4 | 19 | 45 | 10 | 254 | |
1 | 25 | 45 | 5 | 127 | |
Stainless steel | 10GA | 3 | 45 | 150 | 3810 |
1/4 | 6 | 45 | 55 | 1397 | |
3/8 | 10 | 45 | 32 | 813 | |
1/2 | 12 | 45 | 18 | 457 | |
3/4 | 19 | 45 | 9 | 229 | |
Aluminum | 10 GA | 3 | 45 | 280 | 7112 |
1/4 | 6 | 45 | 100 | 2540 | |
3/8 | 10 | 45 | 42 | 1067 | |
*Maximum cut speeds are the results of Hypertherm’s laboratory testing. For optimum cut performance, actual cutting speeds may vary based on different cutting applications. Refer to the operator manual for more details.
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
T45 torch consumable parts
For a full torch and consumable breakdown of the handheld plasma systems please download the full catalog.
T45v drag-cutting parts
Shield/Deflector | Retaining cap | Nozzle | Swirl ring | Electrode |
Look for the blue package.
Consumable type | Torch type | Amperage | Shield/Deflector | Retaining cap | Nozzle | Electrode | Swirl ring |
Drag cutting | Hand | 30 | 220569 | 220483 | 220480 | 220478 | 220479 |
45 | 220674 | 220713 | 220671 | 220669 | 220670 | ||
Mechanized | Machine | 45 | 220673 | 220713 or 220719 (Ohmic) | 220671 | 220669 | 220670 |
Gouging | Hand | 220675 | 220713 | 220672 | 220669 | 220670 | |
Machine |
HyAccess consumables
HyAccess™ consumables give you the ability to cut in hard-to-reach places. For more information on HyAccess consumables, visit the HyAccess product page.
Consumable type | Torch type | Amperage | Electrode | Nozzle, cutting | Nozzle, gouging | Retaining cap | Swirl ring |
HyAccess | Hand | 15-45 | 420137 | 420144 | 420147 | 420148 | 220670 |
Consumable kits
Essential consumable kits keep your Powermax up and running with an array of genuine Hypertherm cutting consumables. See chart below for kit contents and ordering information.
Essential kit
Handheld CSA | 851478 |
Handheld CE | 851477 |
Kit contents
Part # | Description | CSA Qty | CEQty |
220674 | Shield | 2 | 2 |
220717 | Deflector | 1 | 0 |
220713 | Retaining cap | 1 | 1 |
220671 | Nozzle 45 A | 6 | 7 |
220718 | Unshielded cutting nozzle | 1 | 0 |
220669 | Electrode | 7 | 7 |
220670 | Swirl ring | 1 | 1 |
Total | 19 parts | 18 parts |
HyAccess kit
Powermax45 | 428337 |
Kit contents
Part # | Part type | Amperage/description | Qty |
420137 | Electrode | 15 - 45 A | 2 |
420144 | Nozzle, cutting | 15 - 45 A | 1 |
420147 | Nozzle, gouging | 15 - 45 A | 1 |
420148 | Retaining cap | 15 - 45 A | 1 |
420211 | Swirl ring* | 15 - 45 A | 1 |
Total | 6 parts |
*Swirl ring part number 220670 is also compatible.
Bulk packages
Kit contents
Contents | Bulk SKU order # | Part type | Qty |
220669 | 228844 | Electrode | 25 |
220671 | 228843 | Nozzle | 25 |
220673 | 228845 | Shield | 10 |
Upgrades
Powermax45 SYNC plasma cutter
For metal workers who want the most versatile system available to gouge, cut, and mark, the Powermax45® SYNC delivers the best return on investment. Part of the Hypertherm® Powermax® family, Powermax45 SYNC features built-in intelligence, a patented single-piece cartridge, and up to 5 times longer consumable life and greater cutting power than higher-amperage competitors.
Field service bulletins (34)
Machine Interface Cable Kit | Remplacement du câble d’interface - Powermax45/45 XP, 65/85/105/125, and SYNC
Optional Oil Removal Air Filter Kit and Element Replacement (Revision 0)
Showing 6 of 34 documents
