Service manuals (3)
Specifications
Input voltages CSA 480/600 V, 3-PH, 50/60 Hz
CE 400 V, 3-PH, 50/60 Hz
CCC 380 V, 3-PH, 50/60 Hz
Input current @ 21.9 kW 300/400/480/600 V, 38/36/31/24 A
Output current 30–125 A
Rated output voltage 175 VDC
Duty cycle @ 40° C (104° F) 100% @ 125 A
Open circuit voltage (OCV)
  • 400/600 CSA: 320 VDC
  • 380 V CCC: 290 VDC
  • 400 V CE: 305 VDC
Dimensions with handles 592 mm D; 274 mm W; 508 mm H (23.3" D; 10.8" W; 20.0" H)
Weight with 7.6 m (25′) torch
  • 480 V, 47,9 kg (105.7 lbs.)
  • 600 V, 47,5 kg (104.7 lbs.)
  • 380 V, 45,2 kg (99.6 lbs.)
  • 400 V, 48,9 kg (107.8 lbs.)
Gas supply Clean, dry, oil-free air or nitrogen
Recommended gas inlet
flow rate/pressure
Cutting: 260 l/min (550 scfh) @ 5.9 bar (85 psi)
Gouging: 212 l/min (450 scfh) @ 4.1 bar (60 psi)
Input power cable length 3 m (10′)*
Power supply type Inverter – IGBT
Engine drive requirement 40 kW for full 125 A output
Certifications CSA-certified for use in the Americas and Asia, except China.
CE, C-Tick, CU/GOST, Ukr, and Serbian – for use in Europe, Australia, Belarus, Kazakhstan, Russia, Serbia, Ukraine, and other countries where accepted.
CCC for use in China.
Warranty Power supplies have a 3-year warranty and torches a 1-year warranty.
*No power cord on some CCC models.
Engine drive rating System output current Performance (arc stretch)
40 kW 125 A Full
30 kW 125 A Limited
30 kW 100 A Full
25 kW 100 A Limited
22.5 kW 75 A Full
20 kW 75 A Limited
20 kW 60 A Full
15 kW 60 A Limited
12 kW 40 A Full
10 kW 40 A Limited
10 kW 30 A Full
8 kW 30 A Limited
Capacity
Capacity Thickness Cut speed
Cutting
Recommended 38 mm (1-1/2″) 457 mm/min (18 ipm)
  44 mm (1-3/4″) 250 mm/min (10 ipm)
Severance (hand cutting) 57 mm (2-1/4″) 125 mm/min (5 ipm)
Pierce * 25 mm (1″)
* Pierce rating for handheld use or with automatic torch height control
Capacity Metal removal rate Groove profile
Gouging
Typical gouge 12,52 kg/hr
(27.6 lbs./hr)
4,3 mm - 7,9 mm D x 6,1 mm - 9,9 mm W
(0.17-0.31″ D x 0.24-0.39″ W)
Greener Cuts logoEnvironmental stewardship is a core value of Hypertherm. Our Powermax products are engineered to meet and exceed global environmental regulations including the RoHS directive.
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
Mechanized cutting
TorchOperating rangeShieldRetaining cap / Retaining cap (ohmic)NozzleElectrodeSwirl ring
Duramax Hyamp torches - Machine - 180° 30 A - 45 A 420168 220977 / 420156 (Ohmic) 420158 220971 220997
Duramax Hyamp torches - Machine - 180° 45 A - 65 A 420168 220977 / 420156 (Ohmic) 420169 220971 220997
Duramax Hyamp torches - Machine - 180° 65 A - 125 A 220976 220977 / 420156 (Ohmic) 220975 220971 220997
Duramax Hyamp torches - Mini machine - 180° 30 A - 45 A 420168 220977 / 420156 (Ohmic) 420158 220971 220997
Duramax Hyamp torches - Mini machine - 180° 45 A - 65 A 420168 220977 / 420156 (Ohmic) 420169 220971 220997
Duramax Hyamp torches - Mini machine - 180° 65 A - 125 A 220976 220977 / 420156 (Ohmic) 220975 220971 220997
Duramax Hyamp torches - Robotic - 180° 30 A - 45 A 420168 220977 / 420156 (Ohmic) 420158 220971 220997
Duramax Hyamp torches - Robotic - 180° 45 A - 65 A 420168 220977 / 420156 (Ohmic) 420169 220971 220997
Duramax Hyamp torches - Robotic - 180° 65 A - 125 A 220976 220977 / 420156 (Ohmic) 220975 220971 220997
Duramax Hyamp torches - Robotic - 45° 30 A - 45 A 420168 220977 / 420156 (Ohmic) 420158 220971 220997
Duramax Hyamp torches - Robotic - 45° 45 A - 65 A 420168 220977 / 420156 (Ohmic) 420169 220971 220997
Duramax Hyamp torches - Robotic - 45° 65 A - 125 A 220976 220977 / 420156 (Ohmic) 220975 220971 220997
Duramax Hyamp torches - Robotic - 90° 30 A - 45 A 420168 220977 / 420156 (Ohmic) 420158 220971 220997
Duramax Hyamp torches - Robotic - 90° 45 A - 65 A 420168 220977 / 420156 (Ohmic) 420169 220971 220997
Duramax Hyamp torches - Robotic - 90° 65 A - 125 A 220976 220977 / 420156 (Ohmic) 220975 220971 220997
Accessories
Air filtration kits
Hypertherm air filtration kits protect Powermax systems against contaminated air and moisture from air lines.
Read more
Automated communication kits
Upgrade kits for the Powermax65®/85 and Powermax65/85/105 SYNC™ systems for automated applications.
Read more
Leather torch sheaths
The Hypertherm leather torch sheath provides additional protection for torch leads against cuts, burn-through and abrasion.
Read more
Plasma angle cutting guides
Plasma angle cutting guide is designed for accurate hand cuts of angles and square edges.
Read more
Plasma circle cutting guide
Plasma circle cutting guides cut circles up to 28″ in diameter.
Read more
Powermax EtherCAT Interface for EDGE Connect
The Powermax® EtherCAT® Interface is an all-in-one adapter that allows a digital connection between the Powermax equipment and the EDGE® Connect CNC. This allows faster equipment setup, an intuitive operator interface, and access to real-time diagnostics information.
Read more
System dust covers
Hypertherm system dust covers are made from a flame-retardant vinyl designed to protect your Powermax plasma cutting system from dust and dirt.
Read more
Torch alignment guide for off-table beveling
To make the off-table bevel process better suited for plasma cutting, Hypertherm offers a torch alignment guide and V-bevel process charts for Powermax65®/85/105/125 or MAXPRO200® systems.
Read more
Wheel/gantry mount kits
Hypertherm wheel and gantry kits for added mobility to move Powermax plasma cutting systems.
Read more
Field service bulletins (20)
Showing 20 of 20 documents
Showing of 20 documents
Show all
Technical support
