Operator and instruction manuals (2)
Showing 2 of 2 documents
Showing of 2 documents
Specifications
PowerDredge self-tipping hopper
Dimensions 1,981 mm X 1,093 mm X 1,220 mm (78 inch X 43 inch X 48 inch)
Empty weight 492 kg (1,085 lbs)
  Allow space in front of the self-tipping hopper for forklift vehicle access to remove the bag
PowerDredge diaphragm pump
Dimensions 368 mm X 429 mm X 308 mm (14.5 inch X 16.9 inch X 12.1 inch)
Weight 22 kg (49 lb)
  Air requirement is a minimum of 2 bar at 140 slpm (30 psi at 5 scfm)
  Maximum distance between the pump and the cutting table is 600 mm (2 feet)
Technical support
