XPR170 plasma cutting system
Interactive manuals now available
Find answers quickly to your installation, troubleshooting questions, and more. Select a manual.
How-to videos (1)
Showing 1 of 1 Videos
Operator and instruction manuals (10)
.XPR170 Plasma Instruction Manual (Revision 8) ADDENDUM
Showing 6 of 10 documents
Service manuals (2)
XPR Torch Rebuild and Filter Kit Maintenance Guide (Revision 2) (English)
XPR300 Torch Rebuild and Filter Kit Maintenance Guide (Revision 2) (Multilingual)
Showing 2 of 2 documents
Application notes (4)
CNC Communication Protocol for XPR cutting systems with the 141545 main control PCB (Revision 3)
Text Marking with ProNest and Phoenix Application Note (Revision 2)
Update XPR Firmware through Phoenix over EtherCAT (Revision 3)
Showing 4 of 4 documents
Specifications
| Maximum open-circuit voltage (U0) | 360 VDC |
| Maximum output current | 170 A |
| Maximum output power | 35.7 kW |
| Output voltage | 50 VDC–210 VDC |
| 100% duty arc voltage | 210 V |
| Duty cycle rating | 100% at 35.7 kW, 40° C (104° F) |
| Operational ambient temperature range | -10° C–40° C (14° F–104° F) |
| Power factor | 0.98 at 35.7 kW |
| Insulation | Class H |
| EMC emissions classification (CE models only) | Class A |
| Lift points |
Top lift eye weight rating 454 kg (1,000 lb.) Bottom lift truck slots |
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
Mild steel
| Amperage | Process | Shield cap |
Shield | Nozzle retaining cap |
Nozzle | Swirl ring | Electrode | Water tube |
| 50 A | O2/Air | 420200 | 420237 | 420365 | 420234 | 420233 | 420231 | 420368 |
| 80 A | O2/Air | 420200 | 420246 | 420365 | 420243 | 420242 | 420240 | 420368 |
| 130 A | O2/Air | 420200 | 420255 | 420365 | 420252 | 420242 | 420249 | 420368 |
| 170 A | O2/Air | 420200 | 420513 | 420365 | 420261 | 420260 | 420258 | 420368 |
Non-ferrous
| Air/Air | 420200 | 420291 | 420365 | 420288 | 420314 | 420294 | 420368 | |
| Air/Air | 420200 | 420309 | 420365 | 420297 | 420323 | 420294 | 420368 | |
| Air/Air | 420200 | 420309 | 420365 | 420306 | 420323 | 420294 | 420368 | |
| 130 A | N2/N2 | 420200 |
420318 |
420365 |
420315 |
420314 | 420356 | 420368 |
420356 |
420368 |
| Air/Air | 420200 | 420513 | 420365 | 420524 | 420260 | 420258 | 420368 |
XPR Gouging Consumables
Mild Steel
| Amperage | Process | Shield cap | Shield | Nozzle retaining cap |
Nozzle* | Swirl ring | Electrode | Water tube |
| 170A | O2/Air | 420200 | 10086659 | 420365 | 10087904 (.140) Bore |
420242 | 10086653 | 420368 |
| 300A | O2/Air | 420200 | 10086659 | 420365 | 10086655 (.180) Bore |
| 460A | O2/Air | 420200 | 10086659 | 420365 | 10086657 (.195) Bore |
*Reference "XPR Gouging Charts for Nozzle"
Stainless Steel
| 170A | H2-Ar/N2 | 420200 | 10086659 | 420365 | 10087907 (.165) Bore |
420242 | 10086650 | 420368 |
| N2/N2 | 420200 | 10086659 | 420365 | 10087907 (.165) Bore |
| 300A |
H2-Ar/N2 | 420200 | 10086659 | 420365 | 10087909 (.210) Bore |
| N2/N2 | 420200 | 10086659 | 420365 | 10086655 (.180) Bore |
| 460A |
H2-Ar/N2 | 420200 | 10086659 | 420365 | 10087911 (.250) Bore |
| N2/N2 | 420200 | 10086659 | 420365 | 10087909 (.210) Bore |
XPR170 starter kits
| Part number | Description |
| 428842 | XPR170 mild steel consumables starter kit (torch included) |
| 428841 | XPR170 non-ferrous consumables starter kit (torch included) |
| 428840 | XPR170 mild steel consumables starter kit |
| 428843 | XPR170 non-ferrous consumables starter kit |
| 428944 | XPR170 Core console non-ferrous consumables starter kit |
Preventive maintenance
XPR torch and filter maintenance kit (with coolant)
XPR® torch and filter maintenance kit (with coolant) includes all necessary parts for your XPR system.
XPR torch and filter maintenance kit (without coolant)
XPR torch and filter maintenance kit (without coolant) includes all necessary parts for your XPR system.
XPR170 preventive maintenance kit (380V – 600V)
Preventive maintenance kits include all necessary parts for your XPR170™ plasma system (380V – 600V).
XPR170 preventive maintenance kit (200V – 240V)
Preventive maintenance kits include all necessary parts for your XPR170® plasma system (200V – 240V).
.XPR Preventive Maintenance Program Instruction Manual (Revision 3)
Field service bulletins (15)
Multi-Ratio Voltage Divider PCB (0 V - 10 V) Installation Steps for XPR, MAXPRO200, and HPRXD (Revision 0)
Phoenix Passwords Field Service Bulletin for End Users (Revision 4)
XPR Control PCB Replacement Steps Field Service Bulletin (Revision 1)
Showing 6 of 15 documents
Technical support
| Resource center |
| Support by product |
| System support |
| Documents library |
| Training |
| FAQs |
| For educators |
| Tradeshows and events |
| Additional resources |
Useful links
Learn about Hypertherm's committment - Elimination, recycling, and reduction of waste is the foundation of a good approach to end-of-life equipment management. Determine the most sustainable path for your system.
