How-to videos (1)
Showing 1 of 1 videos
Showing of 1 videos
Operator and instruction manuals (4)
Showing 4 of 4 documents
Showing of 4 documents
Application notes (2)
Specifications
Maximum open-circuit voltage 360 VDC
Maximum output current 460 A
Maximum output power 102 kW
Output voltage 50–222 VDC
100% duty arc voltage 222 V
Duty cycle rating 100% at 102 kW, 40° C (104° F)
Operational ambient temperature range -10° C–40° C (14° F–104° F)
Power factor 0.98 at 102 kW
Cooling Forced air (Class F)
Insulation Class H
EMC emissions classification (CE models only) Class A
IP rating IP21
Unit dimensions
H = 124.76 cm (49.12″)
L = 127.28 cm (50.11″)
W = 87.3 cm (34.5″)
Lift points
Top lift eye weight rating 680 kg (1,500 lb.)
Bottom life truck slots
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
Mild steel
XPR mild steel consumable stack up
Amperage Process Shield cap Shield Nozzle retaining cap Nozzle Swirl ring Electrode Water tube
30 A O2/O2 420200 420228 420365 420225 420407 420222 420368
50 A O2/Air 420200 420237 420365 420234 420233 420231 420368
80 A O2/Air 420200 420246 420365 420243 420242 420240 420368
130 A O2/Air 420200 420255 420365 420252 420242 420249 420368
170 A O2/Air 420200 420513 420365 420261 420260 420258 420368
220 A O2/Air 420200 420273 420365 420270 420406 420276 420368
300 A O2/Air 420200 420491 420365 420279 420406 420276 420368
460 A O2/Air 420200 520002 420365 520001 420819 420834 420368
Non-ferrous
XPR non-ferrous consumable stackup
40 A N2/N2 420200 420291 420365 420288 420314 420303 420368
Air/Air 420200 420291 420365 420288 420314 420294 420368
60 A N2/N2 420200 420309 420365 420297 420323 420303 420368
F5/N2 420200 420309 420365 420297 420323 420303 420368
N2/H2O 420200 420300 420365 420296 420323 420303 420368
Air/Air 420200 420309 420365 420297 420323 420294 420368
80 A N2/N2 420200 420309 420365 420306 420323 420303 420368
F5/N2 420200 420309 420365 420306 420323 420303 420368
N2/H2O 420200 420300 420365 420290 420323 420303 420368
Air/Air 420200 420309 420365 420306 420323 420294 420368
130 A N2/N2 420200
420318
420365
420315
420314 420356 420368
H2-Ar-N2/N2 420200 420318 420365 420315 420323 420356 420368
N2/H2O 420200 420469 420365 420315 420314 420356 420368
170 A N2/N2 420200 420327 420365 420324 420314
420356
420368
H2-Ar-N2/N2 420200 420327 420365 420324 420323 420356 420368
N2/H2O 420200 420472 420365 420324 420314 420356 420368
Air/Air 420200 420513 420365 420524 420260 420258 420368
300 A N2/N2 420200 420362 420365 420359 420323 420356 420368
H2-Ar-N2/N2 420200 420362 420365 420359 420358 420356 420368
N2/H2O 420200 420475 420365 420359 420323 420356 420368
460 A H2-Ar-N2/N2 420200 420998 420365 420996 420358 420997 420368
XPR460 starter kits
Part number Description
10083904 XPR460 Mild steel consumables starter kit
10083905 XPR460 Mild steel consumables starter kit (torch included)
Field service bulletins (1)
Showing 1 of 1 documents
Showing of 1 documents
Technical support
