MAXPRO200 plasma cutter
Operator and instruction manuals (3)
MAXPRO200 Ecodesign Requirements (Revision 0) (Multilingual)
MAXPRO200 Extreme Bevel Cut Charts Instruction Manual (Revision 0)
Showing 3 of 3 documents
Specifications
Input voltages | 200/208 VAC, 3-PH, 50 Hz, 108/104 A 220 VAC, 3-PH, 50 – 60 Hz, 98 A 240 VAC, 3-PH, 60 Hz, 90 A 380 VAC, 3-PH, 50 Hz, 57 A 400 VAC, CE, 3-PH, 50 – 60 Hz, 54 A 415 VAC, CE, 3-PH, 50 Hz, 52 A 440 VAC, 3-PH, 50 – 60 Hz, 49 A 480 VAC, 3-PH, 60 Hz, 45 A 600 VAC, 3-PH, 60 Hz, 36 A |
Output voltage | 50 – 165 VDC |
Maximum output current | 200 A |
Duty cycle rating | 100% @ 33 kW, at 40° C (104° F) |
Operating temperature | -10° C to 40° C (+14° F to +104° F) |
Power factor | 0.98 @ 33 kW output |
Maximum OCV | 360 VDC |
Dimensions | 102 cm (40.14") H, 69 cm (27.12") W, 105 cm (41.23") L |
Weight | 335 kg (740 lbs) |
Gas supply Plasma gas Shield gas Supply gas pressure |
Air, O2, N2 Air, N2 6.2 +/- 0.7 bar (90 +/- 10 psig) |
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
MAXPRO200 machine torch consumables
Air – Mild steel / Stainless steel / Aluminum
Shield Shield cap Nozzle Swirl ring Electrode Water tube
200 amp - Air consumables - Mild steel / Stainless steel / Aluminum
Amperage | Shield | Shield cap | Nozzle | Swirl ring | Electrode | Water tube |
50 A | 220532 | 220936 | 220890 | 220529 | 220528 | 220521 |
220935 without tab | ||||||
130 A | 220536 | 220936 | 220892 | 220488 | 220487 | 220521 |
200 A | 420045 | 220936 | 420044 | 220488 | 220937 | 220521 |
O2 – Mild steel
200 amp - O2 consumables - Mild steel
50 A | 220532 | 220936 | 220891 | 220529 | 220528 | 220521 |
130 A | 220491 | 220936 | 220893 | 220488 | 220487 | 220521 |
200 A | 220832 | 220936 | 220831 | 220834 | 220937 | 220521 |
N2 – Stainless steel / Aluminum
200 amp - N2 consumables - Stainless steel / Aluminum
130 A | 220536 | 220936 | 220892 | 220529 | 020415 | 220521 |
200 A | 420045 | 220936 | 420044 | 220529 | 020415 | 220521 |
MAXPRO200 hand torch consumables
50 A | 420063 | 220935 | 220890 | 220529 | 220528 | 220521 |
130 A | 420061 | 220935 | 220892 | 220488 | 220487 | 220521 |
200 A | 420058 | 220935 | 420044 | 220488 | 220937 | 220521 |
200 A gouging | 420067 | 220935 | 420066 | 220488 | 220937 | 220521 |
O2 – Mild steel
50 A | 420063 | 220935 | 220891 | 220529 | 220528 | 220521 |
130 A | 420062 | 220935 | 220893 | 220488 | 220487 | 220521 |
200 A | 420059 | 220935 | 220831 | 220834 | 220937 | 220521 |
MAXPRO200 extreme bevel consumables
Air – Mild steel
130 A | 420735 | 220936 | 420829 | 220488 | 420824 | 420823 |
200 A | 420737 | 220936 | 420734 | 220488 | 420732 | 420823 |
O2 – Mild steel
130 A | 420735 | 220936 | 420828 | 220529 | 420824 | 420823 |
200 A | 420737 | 220936 | 420733 | 220488 | 420732 | 420823 |
Preventive maintenance
MAXPRO200 preventive maintenance kits
Preventive maintenance kits include all necessary parts for your MAXPRO200 system.
Upgrades
XPR300 plasma cutting system
Cut faster and use fewer consumables with the XPR300® mechanized plasma cutting system. With unmatched X-Definition® cut quality on mild steel, stainless steel and aluminum, the XPR300 increases cut speed, dramatically improves productivity and slashes operating costs.
Accessories
Torch alignment guide for off-table beveling
To make the off-table bevel process better suited for plasma cutting, Hypertherm offers a torch alignment guide and V-bevel process charts for Powermax65®/85/105/125 or MAXPRO200® systems.
Field service bulletins (15)
Showing 6 of 15 documents
