Operator and instruction manuals (11)
Showing 11 of 11 documents
Showing of 11 documents
Show all
Service manuals (2)
Application notes (4)
Specifications
Maximum open-circuit voltage (U0) 360 VDC
Maximum output current 300 A
Maximum output power 66.5 kW
Output voltage 50 VDC–210 VDC
100% duty arc voltage 210 V
Duty cycle rating 100% at 66.5 kW, 40° C (104° F)
Operational ambient temperature range -10° C–40° C (14° F–104° F)
Power factor 0.98 at 66.5 kW
Cooling Forced air (Class F)
Insulation Class H
EMC emissions classification (CE models only) Class A
Lift points Top lift eye weight rating 680 kg (1,500 lb.)
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
Mild steel
XPR mild steel consumable stack up
Amperage Process Shield cap Shield Nozzle retaining cap Nozzle Swirl ring Electrode Water tube
30 A O2/O2 420200 420228 420365 420225 420407 420222 420368
50 A O2/Air 420200 420237 420365 420234 420233 420231 420368
80 A O2/Air 420200 420246 420365 420243 420242 420240 420368
130 A O2/Air 420200 420255 420365 420252 420242 420249 420368
170 A O2/Air 420200 420513 420365 420261 420260 420258 420368
220 A O2/Air 420200 420273 420365 420270 420406 420276 420368
300 A O2/Air 420200 420491 420365 420279 420406 420276 420368
Non-ferrous
XPR non-ferrous consumable stackup
40 A N2/N2 420200 420291 420365 420288 420314 420303 420368
Air/Air 420200 420291 420365 420288 420314 420294 420368
60 A N2/N2 420200 420309 420365 420297 420323 420303 420368
F5/N2 420200 420309 420365 420297 420323 420303 420368
N2/H2O 420200 420300 420365 420296 420323 420303 420368
Air/Air 420200 420309 420365 420297 420323 420294 420368
80 A N2/N2 420200 420309 420365 420306 420323 420303 420368
F5/N2 420200 420309 420365 420306 420323 420303 420368
N2/H2O 420200 420300 420365 420290 420323 420303 420368
Air/Air 420200 420309 420365 420306 420323 420294 420368
130 A N2/N2 420200
420318
420365
420315
420314 420356 420368
H2-Ar-N2/N2 420200 420318 420365 420315 420323 420356 420368
N2/H2O 420200 420469 420365 420315 420314 420356 420368
170 A N2/N2 420200 420327 420365 420324 420314
420356
420368
H2-Ar-N2/N2 420200 420327 420365 420324 420323 420356 420368
N2/H2O 420200 420472 420365 420324 420314 420356 420368
Air/Air 420200 420513 420365 420524 420260 420258 420368
300 A N2/N2 420200 420362 420365 420359 420323 420356 420368
H2-Ar-N2/N2 420200 420362 420365 420359 420358 420356 420368
N2/H2O 420200 420475 420365 420359 420323 420356 420368
XPR300 starter kits
Part number Description
428618 XPR300 Mild steel consumables starter kit (torch included)
428619 XPR300 Stainless steel consumables starter kit (torch included)
428616 XPR300 Mild steel consumables starter kit
428945 XPR300 Core console non-ferrous consumables starter kit
428617 XPR300 Stainless steel consumables starter kit
Preventive maintenance
XPR torch and filter maintenance kit (with coolant)
XPR® torch and filter maintenance kit (with coolant) includes all necessary parts for your XPR system.
Read more
XPR torch and filter maintenance kit (without coolant)
XPR torch and filter maintenance kit (without coolant) includes all necessary parts for your XPR system.
Read more
XPR300 preventive maintenance kit (200V – 240V)
Preventive maintenance kits include all necessary parts for your XPR300® plasma system (200V – 240V).
Read more
XPR300 preventive maintenance kit (380V – 600V)
Preventive maintenance kits include all necessary parts for your XPR300™ plasma system (380V – 600V).
Read more
Field service bulletins (10)
Showing 10 of 10 documents
Showing of 10 documents
Show all
Technical support
