ArcGlide torch height control
Operator and instruction manuals (2)
ArcGlide THC Ecodesign Requirements (Revision 0) (Multilingual)
Last updated
21/04/2021
Part number: 811330MU
Showing 2 of 2 documents
Specifications
Regulatory | CE, CSA, GOST-R |
Temperature range | -10° C to + 40° C ambient (14° F to 104° F ambient) |
Humidity | 95% RH |
Dimensions | Lifter: 127 mm (5.0″) X 151 mm (5.9″) X 743 mm (29.3″) HMI: 298 mm (11.7″) X 131mm (5.1″) X 118 mm (4.6″) Control module: 359 mm (14.1″) X 157 mm (6.2″) X 206 mm (8.1″) |
Torch mount / breakaway assembly | 11.4 kg (25 lbs) magnetic (recommended) 4.5 kg (10 lbs) magnetic Pneumatic Torch mount options include 51 mm (2″), 44 mm (1-3/4″) and 35 mm (1-3/8″) |
Stroke speed | 15240 mm/min (600 ipm) |
Lift capacity | 11.4 kg (25 lbs) |
Warranty | Two-year warranty standard |
Communication protocol | Hypernet® to CNC Discrete wiring or Hypernet to the plasma system |
Voltage | 115V/230V for the HMI at 50/60hz 115V/230V for the control module at 50/60hz |
Lifter stroke length | 241 mm (9.4″) |
Table types | Downdraft and water table High amperage capacity 1 – 4 plasma system |
Communication protocol | w/ Hypernet – Hypernet to the CNC/HMI with Hypernet or discrete to the plasma w/o Hypernet - Hypernet to the HMI or RS-422 serial to the CNC with discrete to the plasma |
Upgrades
Sensor torch height control
Compatible with EDGE® Connect and other CNCs, Sensor® THC is a full-featured torch height control system that can significantly increase the productivity and profitability of your shape cutting operation. Suitable for high definition and conventional plasma applications.
Field service bulletins (5)
ArcGlide THC Plasma Interface to HPR and Generic CNC with RS422
Last updated
07/12/2010
Part number: 806640
Showing 5 of 5 documents
