Operator and instruction manuals (2)
Duramax Retrofit Torch HRT2 and MRT2 for powermax600, 800, 900, MAX42, and MAX43
Last updated
14/05/2012
Part number: 807530
Showing 2 of 2 documents
Service manuals (1)
Showing 1 of 1 documents
Specifications
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
PAC123T/PAC123M
Upgrades
Duramax retrofit torches for Powermax600/800/900 and MAX42/43 systems
Enhance the performance and productivity of your Powermax600, Powermax800, Powermax900, MAX42, or MAX43 system with a Duramax retrofit torch.
Powermax45 XP plasma cutter
Versatile, professional-grade plasma cutter provides a recommended cut capacity – up to 16 mm (5/8″) – as well as enhanced gouging and marking capabilities.
Field service bulletins (7)
Powermax600 50 foot (15 m) Work Lead Câble de retour Powermax600 15 m (50 pi)
Last updated
07/12/2010
Part number: 803470
Powermax600 Filter/Regulator Assembly Replacement Remplacement du filtre-détendeur
Last updated
07/12/2010
Part number: 805360
Showing 6 of 7 documents
