Operator and instruction manuals (14)
Showing 14 of 14 documents
Showing of 14 documents
Show all
Service manuals (3)
Showing 3 of 3 documents
Showing of 3 documents
Specifications
Cut capacity
Capacity Thickness Cut speed
Recommended 25 mm (1″) 500 mm/min (20 ipm)
  32 mm (1-1/4″) 250 mm/min (10 ipm)
Severance (hand cutting) 38 mm (1-1/2″) 125 mm/min (5 ipm)
Pierce* 20 mm (3/4″)
*Pierce rating for handheld cutting, or mechanized cutting with programmable torch height control.
Maximum removal gouging
Capacity Metal removal rate Gouge profile
Typical gouge 8,2 kg (18.2 lbs.) per hour 3,5 mm D x 6,6 mm W (0.14″ D x 0.26″ W)
General specifications
Input voltages
CSA
  • 200–480 V, 1-PH, 50/60 Hz
  • 200–600 V, 3-PH, 50/60 Hz
CE
  • 380/400 V, 3-PH, 50/60 Hz
Kilowatt output
12.2 kW
Input current
CSA
  • 200/208/240/480, 1-PH 70/68/58/29 A @ 12.2 kW
  • 200/208/240/480/600 V, 3-PH 42/40/35/18/17 A @ 12.2 KW
CE
  • 380/400, 3-PH 20.5/19.5 A
Output current
25–85 A
Rated output voltage
143 VDC
Duty cycle @ 104° F
CSA
  • 60% @ 85 A, 230–600 V, 3-PH
  • 60% @ 85 A, 480 V, 1-PH
  • 50% @ 85 A 240 V, 1-PH
  • 50% @ 85 A, 200–208 V, 3-PH
  • 40% @ 85 A, 200–208 V, 1-PH
  • 100% @ 66 A, 230–600 V, 1/3-PH
CE
  • 60% @ 85 A, 380–400 V, 3-PH
  • 100% @ 66 A, 380–480 V, 3-PH
Open circuit voltage (OCV)
CSA: 305 VDC
CE: 270 VDC
Dimensions with handles
483 mm D; 233 mm W; 430 mm H (19″ D; 9.2″ W; 17″ H)
Weight w/7.6 m (25′) torch
CSA: 32 kg (67 lbs.)
CE: 23.5 kg (52 lbs.)
Gas supply
Clean, dry, oil-free air or nitrogen
Optimum inlet gas pressure
7.6–8.3 bar (110–120 psi)
Minimum inlet gas pressure
5.2 bar (75 psi)
Recommended inlet gas flow rate
Cutting: 210 I/min @ 5.9 bar (450 scfh, 7.5 scfm @ 85 psi)
Gouging: 210 I/min @ 4.8 bar (450 scfh, 7.5 scfm @ 70 psi)
Input power cable length
3 m (10′)
Power supply type
Inverter–IGBT
Engine drive requirement
20 kW for full 85 A output
Electrical efficiency
91.9%
Certifications
  • CSA – for use in the Americas and Asia, except China
  • CE – for use in Europe, Australia & New Zealand - RCM, Serbia, UK - UKCA, Ukraine, and other countries where accepted.
  • CCC – for use in China
Warranty
Power supplies have a 3-year warranty and torches a 1-year warranty
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
CARTRIDGE-85-Drag-Fine-Hand
Drag cutting and FineCut for hand torches
Hypertherm cartridges
Process
Cartridge
85 A
428935
65 A
428931
45 A
FineCut® hand cutting
Drag cartridge:
FineCut cartridge:
CARTRIDGE-85-Mech-standoff-Fine
Process
Cartridge
85 A
428934
65 A
428930
45 A
FineCut® mechanized cutting
Ohmic ring kit
428895
CARTRIDGE-85-MaxControlRemoval-Mech
Process
Cartridge
Max removal gouging 45–85 A
428932
Max control gouging 45–85 A
428933
CARTRIDGE-85-Flushcut
FlushCut
Process
FlushCut™
85 A
428953
65 A
428952
CARTRIDGE-65-HyAccess
HyAccess cartridges
Process
HyAccess™
Drag cutting 65 A
428984
Gouging 65 A
428987
Mechanized cutting 65 A
528079
Accessories
Hypertherm cartridge reader
The Hypertherm cartridge reader provides a simple process for reviewing data stored in Hypertherm cartridges. Data analysis helps customers understand cartridge utilization and identify operator training opportunities.
Read more
Powermax EtherCAT Interface for EDGE Connect
The Powermax® EtherCAT® Interface is an all-in-one adapter that allows a digital connection between the Powermax equipment and the EDGE® Connect CNC. This allows faster equipment setup, an intuitive operator interface, and access to real-time diagnostics information.
Read more
Robotic torch clamp kit
The robotic torch clamp kit is designed to simplify integration of Powermax® robotic torches on robots. The clamp fits perfectly with the torch dimensions and securely holds the torch during cutting applications.
Read more
Field service bulletins (9)
Showing 9 of 9 documents
Showing of 9 documents
Show all
Technical support
