Powermax65 SYNC plasma cutter
How-to videos (7)
Operator and instruction manuals (13)
.Cut Charts for Powermax45/65/85/105 SYNC (Multilingual) (Revision 4)
.Mechanized Cutting with Powermax45/65/85/105 SYNC (Revision 5)
.Operator Manual for Powermax65/85/105 SYNC (Revision 4)
Showing 6 of 13 documents
Service manuals (3)
Service Replacement Parts for SmartSYNC Torches (Revision 1)
Showing 3 of 3 documents
Specifications
Cut capacity
Capacity | Thickness | Cut speed |
Recommended | 20 mm (3/4″) | 500 mm/min (20 ipm) |
25 mm (1″) | 250 mm/min (10 ipm) | |
Severance (hand cutting) | 32 mm (1-1/4″) | 125 mm/min (5 ipm) |
Pierce* | 16 mm (5/8″) |
*Pierce rating for handheld cutting, or mechanized cutting with programmable torch height control.
Maximum removal gouging
Capacity | Metal removal rate | Groove profile |
Typical gouge | 4,0 kg (8.8 lbs.) per hour | 2,9 mm D x 6,4 mm W (0.11″ D x 0.25″ W) |
General specifications
Input voltages |
CSA
CE
Kilowatt output |
9 kW |
Input current |
CSA
CE
Output current |
20–65 A |
Rated output voltage |
139 VDC |
Duty cycle @ 104° F |
CSA
CE
Open circuit voltage (OCV) |
CSA: 295 VDC CE: 270 VDC |
Dimensions with handles |
483 mm D; 233 mm W; 430 mm H (19″ D; 9.2″ W; 17″ H) |
Weight w/7.6 m (25′) torch |
CSA: 29 kg (61 lbs.) CE: 24.1 kg (52.7 lbs.) |
Gas supply |
Clean, dry, oil-free air or nitrogen |
Optimum inlet gas pressure |
7.6–8.3 bar (110–120 psi) |
Minimum inlet gas pressure |
5.2 bar (75 psi) |
Recommended inlet gas flow rate |
Cutting: 210 I/min @ 5.9 bar (450 scfh, 7.5 scfm @ 85 psi) Gouging: 210 I/min @ 4.8 bar (450 scfh, 7.5 scfm @ 70 psi) |
Input power cable length |
3 m (10′) |
Power supply type |
Inverter – IGBT |
Engine drive requirement |
15 kW for full 65 A output |
Electrical efficiency |
91.2% |
Certifications |
Warranty |
Power supplies have a 3-year warranty and torches a 1-year warranty |
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
CARTRIDGE-65-Drag-Fine-Hand
CARTRIDGE-65-Mech-standoff-Fine
CARTRIDGE-65-MaxControlRemoval-Mech
CARTRIDGE-65-FlushCut
Hypertherm cartridges |
Process |
FlushCut™ |
65 A |
Accessories
Hypertherm cartridge reader
The Hypertherm cartridge reader provides a simple process for reviewing data stored in Hypertherm cartridges. Data analysis helps customers understand cartridge utilization and identify operator training opportunities.
Powermax EtherCAT Interface for EDGE Connect
The Powermax® EtherCAT® Interface is an all-in-one adapter that allows a digital connection between the Powermax equipment and the EDGE® Connect CNC. This allows faster equipment setup, an intuitive operator interface, and access to real-time diagnostics information.
Robotic torch clamp kit
The robotic torch clamp kit is designed to simplify integration of Powermax® robotic torches on robots. The clamp fits perfectly with the torch dimensions and securely holds the torch during cutting applications.
Cartridge ohmic ring
The ohmic contact ring clips onto the mechanized cartridge, and connects it via electrical wire to torch height controls (THCs) that support the use of ohmic contact to find the surface of the workpiece before each cut.
Field service bulletins (10)
Cartridge Reader and App | Lecteur de cartouche et application - Powermax65/85/105 SYNC
Heat Shield Kits for T Series, Duramax, Duramax Hyamp Handheld Torches Écran de chaleur des torches manuelles 804230 revision 6
Showing 6 of 10 documents
