Operator and instruction manuals (4)
Service manuals (1)
Showing 1 of 1 documents
Showing of 1 documents
Application notes (1)
Specifications
Input voltages 120-240 V, 1-PH, 50/60 Hz
Input current @ 3.8 kW 120-240 V, 1-PH, 25-18.8 A
Output current 15-30 A
Rated output voltage 125 VDC
Duty cycle @ 40°C (104°F) 35%, 240 V
20%, 120 V
Open circuit voltage (OCV) 256 VDC
Dimensions with handles 356 mm (14.0") D; 168 mm (6.6") W; 305 mm (12.0") H
Weight w/ 4,5 m (15') torch CSA: 9.7 kg (21.4 lbs)
CE, CCC: 9.5 kg (21 lbs)
Gas Supply Clean, dry, oil-free air or nitrogen
Recommended gas inlet
flow rate / pressure
113.3 l/min (4 scfm) at 5.5 bar (80 psi)
Input power cable length 3 m (10')
Power supply type Inverter - IGBT
Engine drive requirement 5.5 kW for full 30 A output
Certifications CSA-certified for use in the Americas and Asia, except China
CE, C-Tick, CU/GOST, Ukr, and Serbian — for use in Europe, Australia, Belarus, Kazakhstan, Russia, Serbia, Ukraine, and other countries where accepted.
CCC for use in China.
Warranty Power supplies have a 3-year warranty and torches a 1-year warranty.
Greener Cuts logoEnvironmental stewardship is a core value of Hypertherm. Our Powermax products are engineered to meet and exceed global environmental regulations including the RoHS directive.
Accessories
Adjustable eye shades
The Hypertherm adjustable eye shades are designed for use with < 40 amp plasma cutting systems.
Read more
Arc-rated metalworking jersey
The Hypertherm arc-rated metalworking jersey is top quality washable welder wear made from modacrylic fabric for flame and arc flash resistance.
Read more
Field service bulletins (16)
Showing 16 of 16 documents
Showing of 16 documents
Show all
Technical support
