Powermax30 AIR plasma cutter
How-to videos (5)
Operator and instruction manuals (3)
Powermax30 AIR and Powermax30 XP Ecodesign Requirements (Revision 0) (Multilingual)
Safety and Compliance Manual (Revision 9) (Multilingual)
Showing 3 of 3 documents
Service manuals (1)
Showing 1 of 1 documents
Specifications
Input voltages | 120-240 V, 1-PH, 50/60 Hz |
Input current @ 2.5 kW | 120-240 V, 1-PH, 29-15 A |
Output current | 15-30 A |
Rated output voltage | 83 VDC |
Duty cycle @ 40°C (104°F) | 35%, 240 V 20%, 120 V |
Open circuit voltage (OCV) | 256 VDC |
Dimensions with handles | 420 mm (16.5") D; 195 mm (7.7") W; 333 mm (13.1") H |
Weight w/ 4,5 m (15') torch | 13.5 kg (29.8 lbs) |
Input power cable length | 3 m (10') |
Power supply type | Inverter - IGBT |
Engine drive requirement | 5.5 kW for full 30 A output |
Certifications | CSA-certified for use in the Americas and Asia, except China CE, C-Tick, CU/GOST, Ukr, and Serbian — for use in Europe, Australia, Belarus, Kazakhstan, Russia, Serbia, Ukraine, and other countries where accepted. |
Warranty | Power supplies have a 3-year warranty and torches a 1-year warranty. |
Cut capacity
Capacity | Thickness | Cut speed |
Cutting |
Recommended | 8 mm (5/16") | 500 mm/min (20 ipm) |
10 mm (3/8") | 250 mm/min (10 ipm) | |
Severance | 16 mm (5/8") | 125 mm/min (5 ipm) |
Cutting with 120 V input power
The maximum recommended output of 20 A, the cut capacities are:
- 3 mm (10 gauge) at 762 mm/min (30 ipm)
- 6 mm (1/4") at 355 mm/min (14 ipm)
- 10 mm (3/8") at 125 mm/min (5 ipm)
Environmental stewardship is a core value of Hypertherm. Our Powermax products are engineered to meet and exceed global environmental regulations including the RoHS directive.
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
Accessories
Adjustable eye shades
The Hypertherm adjustable eye shades are designed for use with < 40 amp plasma cutting systems.
System dust covers
Hypertherm system dust covers are made from a flame-retardant vinyl designed to protect your Powermax plasma cutting system from dust and dirt.
Field service bulletins (6)
Powermax30 AIR Cable Tie Addendum (Addendum relatif à l’attache autobloquante) 811340 revision 0
Powermax30/30 XP/30 AIR/45/45 XP Ground Clamp Replacement Remplacement de pince de masse 806530 revision 3
Showing 6 of 6 documents
