Powermax105 SYNC plasma cutter
How-to videos (7)
Operator and instruction manuals (13)
.Cut Charts for Powermax45/65/85/105 SYNC (Multilingual) (Revision 4)
.Mechanized Cutting with Powermax45/65/85/105 SYNC (Revision 5)
.Operator Manual for Powermax65/85/105 SYNC (Revision 4)
Showing 6 of 13 documents
Service manuals (3)
Service Replacement Parts for SmartSYNC Torches (Revision 1)
Showing 3 of 3 documents
Specifications
Cut capacity
Capacity | Thickness | Cut speed |
Recommended | 32 mm (1-1/4″) | 500 mm/min (20 ipm) |
38 mm (1-1/2″) | 250 mm/min (10 ipm) | |
Severance (hand cutting) | 50 mm (2″) | 125 mm/min (5 ipm) |
Pierce* | 22 mm (7/8″) |
*Pierce rating for handheld cutting, or mechanized cutting with programmable torch height control.
Maximum removal gouging
Capacity | Metal removal rate | Gouge profile |
Typical gouge | 8,6 kg (19.1 lbs.) per hour | 6,6 mm D x 6,0 mm W (0.26″ D x 0.24″ W) |
General specifications
Input voltages |
CSA
CE/CCC
Kilowatt output |
16.8 kW |
Input current |
CSA 200/208/240/480/600 V, 3-PH 58/56/49/25/22 A @ 16.8 kW
CE/CCC
Output current |
30–105 A |
Rated output voltage |
160 VDC |
Duty cycle @ 104° F |
CSA
CE/CCC
Open circuit voltage (OCV) |
CSA – 300 VDC CE/CCC – 288 VDC |
Dimensions with handles |
592 mm D; 274 mm W; 508 mm H (23.3″ D; 10.8″ W; 20.0″ H) |
Weight w/7,6 m (25′) torch |
CSA 45.3 kg (95 lbs.)
CE/CCC 230–400 V, 42.7 kg (94 lbs.) 400 V, 39.4 kg (87 lbs.) |
Gas supply |
Clean, dry, oil-free air or nitrogen |
Optimum inlet gas pressure |
7.6–8.3 bar (110–120 psi) |
Minimum inlet gas pressure |
5.5 bar (80 psi) |
Recommended inlet gas flow rate |
Cutting: 260 I/min @ 5.9 bar (550 scfh, 9.2 scfm @ 90 psi) Gouging: 260 I/min @ 4.8 bar (550 scfh, 9.2 scfm @ 70 psi) |
Input power cable length |
3 m (10′) |
Power supply type |
Inverter–IGBT |
Engine drive requirement |
30 kW for full 105 A output |
Electrical efficiency |
91% |
Certifications |
Warranty |
Power supplies have a 3-year warranty and torches a 1-year warranty |
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
CARTRIDGE-105-Drag-Fine-Hand
Hypertherm cartridges |
Process |
Cartridge |
105 A |
85 A |
65 A |
45 A |
FineCut® hand cutting |
Drag cartridge:
FineCut cartridge:
CARTRIDGE-105-Mech-standoff-Fine
CARTRIDGE-105-MaxControlRemoval-Mech
Accessories
Hypertherm cartridge reader
The Hypertherm cartridge reader provides a simple process for reviewing data stored in Hypertherm cartridges. Data analysis helps customers understand cartridge utilization and identify operator training opportunities.
Powermax EtherCAT Interface for EDGE Connect
The Powermax® EtherCAT® Interface is an all-in-one adapter that allows a digital connection between the Powermax equipment and the EDGE® Connect CNC. This allows faster equipment setup, an intuitive operator interface, and access to real-time diagnostics information.
Robotic torch clamp kit
The robotic torch clamp kit is designed to simplify integration of Powermax® robotic torches on robots. The clamp fits perfectly with the torch dimensions and securely holds the torch during cutting applications.
Field service bulletins (10)
Cartridge Reader and App | Lecteur de cartouche et application - Powermax65/85/105 SYNC
Heat Shield Kits for T Series, Duramax, Duramax Hyamp Handheld Torches Écran de chaleur des torches manuelles 804230 revision 6
Showing 6 of 10 documents
