Operator and instruction manuals (4)
MicroEDGE Pro Shape Cutting Control Instruction Manual (Revision 4)
Phoenix Software V9 Series Installation and Setup Manual (Revision 11)
Phoenix Software V9 Series Programmer's Reference (V9.76.0) (Revision 9)
Showing 4 of 4 documents
Application notes (4)
Phoenix Software Demonstration Application Note (Revision 0)
Specifications
Flexible configurations
The MicroEDGE Pro offers multiple back-door interfaces for cutting machine manufacturer integration or field upgrades for existing cutting machines. CNC size, connector layout and mounting is consistent with earlier models to allow the manufacturer to configure the CNC to match the cutting machine design and functionality.
Interface options | ![]() HyPath analog | ![]() SERCOS II & III digital | ![]() Picopath analog |
Axis count | 2 - 4 | 2 - 12 | 2 - 4 |
Inputs / Outputs | 24 positive logic inputs and 24 relay outputs | 512 digital inputs and 512 digital outputs | 12 negative logic inputs and 12 negative logic outputs |
Sensor THC Interface | 0 - 2 | 0 - 8 | 0 - 2 |
ArcGlide Interface | 0 - 4 via Hypernet | 0 - 4 via Hypernet | 0 - 4 via Hypernet |
Wireless networking | Standard | Standard | Optional |
Standard features
Application Software | Phoenix shape cutting control software |
Operating system | Windows® XPe |
Display and keyboard | Customer supplied - touchscreen and standard LCD supported |
Communication ports | Ethernet LAN, Hypernet, USB and RS-232/422/485 isolated serial |
Dimensions | 239 mm (9.4") high x 465 mm (18.3") wide x 335 mm (13.2") deep |
Temperature range | -10° C to 40° C ambient (14° F to 104° F ambient) |
Warranty | Two -year warranty |
Regulatory compliance | CE, CSA, GOST-R |
Operating voltage and frequency | 100 – 240 V, 50/60 Hz |
Software utilities | Part Program Support (PPS), Remote Help, networking, Autogas support, DXF import, and simple shape nesting |
Upgrades
ArcGlide torch height control
The ArcGlide torch height control was last manufactured in December 2023 and is no longer available for sale from Hypertherm. Hypertherm's Technical Service department will continue to support this model.
Sensor torch height control
Compatible with EDGE® Connect and other CNCs, Sensor® THC is a full-featured torch height control system that can significantly increase the productivity and profitability of your shape cutting operation. Suitable for high definition and conventional plasma applications.
Field service bulletins (7)
Phoenix Passwords Field Service Bulletin for End Users (Revision 3)
Showing 6 of 7 documents
