How-to videos (3)
Operator and instruction manuals (7)
Showing 6 of 7 documents
Service manuals (4)
HPR and HPR XD Torch Rebuild and Filter Kit Maintenance Guide (Revision 1) (Multilingual)
HPR and HPRXD Torch Rebuild Kit Maintenance Guide (Revision 1) (English)
HPR and HPRXD Torch Rebuild Kit Maintenance Guide (Revision 2) (Multilingual)
Showing 4 of 4 documents
Application notes (1)
Showing 1 of 1 documents
Specifications
Mild steel cut capacity | Dross free Production pierce Maximum cutting capacity |
32 mm (1-1/4") 38 mm (1-1/2") 64 mm (2-1/2") |
Stainless steel cut capacity | Production pierce Maximum cutting capacity |
32 mm (1-1/4") 50 mm (2") |
Aluminum cut capacity | Production pierce Maximum cutting capacity |
25 mm (1") 50 mm (2") |
Speed (Mild steel) |
Book specification at highest output current | 12 mm (1/2") 3850 mm/m (145 ipm) |
Cut angle | ISO 9013 range* | 2-4 |
Weldability | Ready to weld | |
Process gases by material (Plasma/shield) |
Mild steel Stainless steel Aluminum |
02/Air, 02/02, Ar/Air |
Process amps (Cutting) |
Not all processes available for all materials | 30-260 |
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
HPR cartridge
HPR cartridge consumablesNew!
Mild steel process | Retaining cap | Cartridge (10 pk) | Water tube | Torch body |
80 A (standard cutting / bevel cutting)* | 420708 | 420803 | 420728 | 420729 |
130 A (standard cutting / bevel cutting)* | 420708 | 420705 | 420728 | 420729 |
260 A (standard cutting / bevel cutting)* | 420708 | 420715 | 420728 | 420729 |
HPR cartridge kitsNew!
Type | Kit p/n | Includes p/n | Description | Quantity |
Torch starter kit | 528101 | 420729 | Torch body | 1 |
420728 | Water tube | 1 | ||
420708 | Retaining cap | 1 | ||
528107 | Kit: O-ring cartridge torch | 1 | ||
Cartridge 3-pk kits |
528103 |
420705 |
Kit: Cartridge, 130 A | 3 | |
528104 | 420715 | Kit: Cartridge, 260 A | 3 | |
528105** | 420803, 420705, 420715 | Kit: Cartridge, multi-amps | 3 |
** Note: 528105 cartridge multi-amps kit contains (1) of each amperage (80 A, 130 A, and 260 A).
HPR260XD standard consumables
Mild steel
260 amp consumables - mild steel
Amperage | Shield cap |
Shield | Nozzle retaining cap |
Nozzle | Swirl ring | Electrode | SilverPlus electrode | Water tube |
30 A | 220747 | 220194 | 220754 | 220193 | 220180 | 220192 | ______ | 220340 |
50 A | 220747 | 220555 | 220754 | 220554 | 220553 | 220552 | ______ | 220340 |
80 A | 220747 | 220189 | 220756 | 220188 | 220179 | 220187 | 420566 | 220340 |
130 A | 220747 | 220183 | 220756 | 220182 | 220179 | 220181 | 220665 | 220340 |
200 A | 220637 | 220761 | 220757 | 220354 | 220353 | 220352 | 220666 | 220340 |
260 A | 220637 | 220764 | 220760 | 220439 | 220436 | 220435 | 220668 | 220340 |
80 A bevel | 220637 | 220742 | 220845 | 220806 | 220179 | 220802 | ______ | 220700 |
130 A bevel | 220637 | 220742 | 220740 | 220646 | 220179 | 220649 | ______ | 220700 |
200 A bevel | 220637 | 220658 | 220845 | 220659 | 220353 | 220662 | ______ | 220700 |
260 A bevel | 220637 | 220741 | 220740 | 220542 | 220436 | 220541 | ______ | 220571 |
* 260 A bevel | 220637 | 220897 | 220896 | 220898 | 220436 | 220899 | ______ | 220571 |
* Recommended for use if you have excessive slag, or the torch is misfiring, when using standard consumables.
Stainless steel
260 amp - stainless steel - above 4" thick
Nozzle | Swirl ring | Electrode | SilverPlus | Water tube |
45 A | 220747 | 220202 | 220755 | 220201 | 220180 | 220308 | 220340 | |
60 A HDi | 220747 | 220815 | 220814 | 220847 | 220180 | 220339 | 220340 | |
80 A | 220747 | 220338 | 220755 | 220337 | 220179 | 220339 | 220340 | |
130 A | 220747 | 220198 | 220755 (H35) | 220197 | 220179 | 220307 | 220340 | |
220756 (N2) | ||||||||
200 A | 220637 | 220762 | 220758 | 220343 | 220342 | 220307 | 220340 | |
260 A | 220637 | 220763 | 220758 | 220406 | 220405 | 220307 | 220340 | |
130 A bevel | 220637 | 220738 | 220739 | 220656 | 220179 | 220606 | 220571 | |
260 A bevel | 220637 | 220738 | 220739 | 220607 | 220405 | 220606 | 220571 |
Aluminum
260 amp - aluminum consumables - above 4" thick
45 A | 220747 | 220202 | 220756 | 220201 | 220180 | 220308 | 220340 | |
130 A | 220747 | 220198 | 220755 (H35) | 220197 | 220179 | 220307 (H35) | 220340 | |
220756 (Air) | 220181 (Air) | |||||||
200 A | 220637 | 220762 | 220759 | 220346 | 220342 | 220307 | 220340 | |
HPR260XD starter kits
Designed especially for your HPR260XD system, the Hypertherm consumable kit contains all the necessary consumables and accessories you need to get up-and-cutting. Customers can choose either mild or stainless steel/aluminum consumable starter kits.
Kit type (MS) | HPR260XD mild steel starter kit (260 A and below) |
Kit part number | 228422 |
Description | Kit contains all the necessary consumables and accessories for mild steel cutting at 260 A and below |
Kit type (MS) | HPR260XD mild steel bevel starter kit (260 A and below) |
Kit part number | 428627 |
Description | Kit contains all the necessary consumables and accessories for mild steel bevel cutting at 260 A and below |
Kit type (AL/SS) | HPR260XD aluminum and stainless steel starter kit (260 A and below) |
Kit part number | 228423 |
Description | Kit contains all the necessary consumables and accessories for aluminum and stainless steel cutting at 260 A and below |
Preventive maintenance
HPR260XD preventive maintenance kits
Preventive maintenance kits include all necessary parts for your HPR260XD system.
HPR260XD Auto Gas Preventive Maintenance Program Instruction Manual (Revision 1)
HPR260XD Manual Gas Preventive Maintenance Program Instruction Manual (Revision 1)
Upgrades
SilverPlus electrodes
SilverPlusĀ® electrodes last over two times longer than standard copper electrodes significantly lower operating costs and reducing the number of changeouts.
XPR300 plasma cutting system
Cut faster and use fewer consumables with the XPR300® mechanized plasma cutting system. With unmatched X-Definition® cut quality on mild steel, stainless steel and aluminum, the XPR300 increases cut speed, dramatically improves productivity and slashes operating costs.
Field service bulletins (11)
Showing 6 of 11 documents
