Operator and instruction manuals (4)
Phoenix Software V9 Series Installation and Setup Manual (Revision 11)
Last updated
22/12/2014
Part number: 806410
Phoenix Software V9 Series Programmer's Reference (V9.76.0) (Revision 9)
Last updated
22/12/2014
Part number: 806420
Showing 4 of 4 documents
Application notes (3)
Phoenix Software Demonstration Application Note (Revision 0)
Last updated
05/05/2014
Part number: 808700
Showing 3 of 3 documents
Specifications
Operating system | Windows® XPe |
Hard drive | SATA drive |
Display | 15" glass touchscreen (surface acoustic wave technology) |
Memory | ≥1GB |
Communications / Ports | Wireless Networking, LAN, Hypernet, Two USB and RS-232/422 serial ports |
Dimensions | 435 mm (17.13") W; 490.9 mm (19.33") H; 377.2 mm (14.85") D |
Temperature range | -10° C to 40° C ambient (14° F to 104° F ambient) |
Warranty | Two-year |
Regulatory compliance | CE, CSA, GOST-R |
Operator's console | Two-station including joystick and two speedpots |
Operating voltage and frequency | 100 – 240V, 50/60 Hz, 10.0 A at 100 VAC/4.1 A at 240 VAC |
Software utilities | Part Program Support (PPS), Remote Help, networking, Autogas support, DXF import, and simple shape nesting |
Axis count | 2 – 4 |
Inputs/Outputs | 12 /12 |
Options | Sensor Ti lifter, interface diagnostic kit, axes servo motors and cables |
Information subject to change without notice.
Upgrades
EDGE Connect CNC system
Hypertherm Computer Numeric Control (CNC) delivers unmatched reliability, powerful embedded capabilities, and a high level of customizability.
Sensor torch height control
Compatible with EDGE® Connect and other CNCs, Sensor® THC is a full-featured torch height control system that can significantly increase the productivity and profitability of your shape cutting operation. Suitable for high definition and conventional plasma applications.
Field service bulletins (4)
Phoenix Passwords Field Service Bulletin for End Users (Revision 3)
Last updated
07/06/2023
Part number: 808770
