Operator and instruction manuals (7)
Showing 6 of 7 documents
Application notes (4)
Phoenix Software Demonstration Application Note (Revision 0)
Last updated
05/05/2014
Part number: 808700
Showing 4 of 4 documents
Specifications
Flexible configurations
Interface options | ![]() HyPath analog | ![]() SERCOS II & III digital | ![]() Picopath analog |
Axis count | 2 - 6 | 2 - 12 | 2 - 4 |
Inputs / Outputs | 24 or 48 positive logic inputs and 24 or 48 relay outputs | 512 digital inputs and 512 digital outputs | 12 negative logic inputs and 12 negative logic outputs |
Sensor THC Interface | 0 - 2 | 0 - 8 | 0 - 2 |
ArcGlide Interface | 0 - 4 via Hypernet | 0 - 4 via Hypernet | 0 - 4 via Hypernet |
Wireless networking | Standard | Standard | Standard |
Standard features
Operating system | Windows® XPe |
Hard drive | SATA drive |
Display | 15" glass touchscreen (surface acoustic wave technology) |
Memory | ≥1GB |
USB interface | Two USB 2.0 ports |
Dimensions | 435 mm (17.125") W; 463 mm (18.22") H; 316 mm (12.43") D |
Temperature range | -10° C to 40° C ambient (14° F to 104° F ambient) |
Warranty | Two -year warranty standard |
Regulatory compliance | CE, CSA |
Operator’s console | Two-station Opcon standard |
Operating voltage and frequency | 100 – 240 V, 50/60 Hz |
Software utilities | Part Program Support (PPS), Remote Help, networking, Autogas support, DXF import, and simple shape nesting |
Upgrades
EDGE Connect CNC system
Hypertherm Computer Numeric Control (CNC) delivers unmatched reliability, powerful embedded capabilities, and a high level of customizability.
Sensor torch height control
Compatible with EDGE® Connect and other CNCs, Sensor® THC is a full-featured torch height control system that can significantly increase the productivity and profitability of your shape cutting operation. Suitable for high definition and conventional plasma applications.
Field service bulletins (7)
Phoenix Passwords Field Service Bulletin for End Users (Revision 3)
Last updated
07/06/2023
Part number: 808770
Repositioning SERCOS II and SERCOS III Boards in EDGE Pro and MicroEDGE Pro CNCs
Last updated
09/01/2014
Part number: 808280
