Every cutting process has particular benefits and shortcomings that you should take into account before deciding on a cutting method. Also keep in mind that a combination of processes may be best for a particular application.
![]() Plasma |
![]() Oxyfuel |
![]() Laser |
![]() Waterjet |
![]() Other mechanical tools |
Common attributes | ||||||
Industrial cutting category | Thermal |
Thermal |
Thermal |
Erosive | Mechanical | |
Types of materials | Most metals | Carbon steel | Range of materials | Nearly anything | Metal, wood, plastic | |
Material thickness | Up to 80 mm (3″) | 50 mm (2″) and above with widest range of thicknesses | Typically 6 mm (1/4″) and below, but up to 30 mm (1.25") in some cases | Up to 305 mm (12″) and thicker with modifications to material support | Typically up to 25 mm (1″) | |
Cut quality | Very good | Very good | Excellent | Exceptional | Good | |
Speed when cutting ideal thickness |
Fast | Fast (though requires pre-heat time) |
Fast | Slow | Slow | |
Operating costs | $ - $$ | $$ | $$ (Higher for CO2 lasers) |
Capital equipment cost | $ - $$$ | $ | $$$$ | $$$ | $ - $$$$ | |
Portability | X (air plasma only) |
X | - | - | X | |
Heat affected zone | Larger | Larger | Smaller | None | Maybe | |
Safety enclosure required | No | No | Yes | No | No | |
Ability to cut rusty or painted material | Yes | Yes | With limitations | Yes | Yes | |
Learn about plasma | Learn about oxyfuel | Learn about laser | Learn about waterjet |
