Hypertherm Powermax cartridge consumable platform
With its revolutionary single-piece design, the new cartridge consumable for Powermax® systems will change the way you cut and gouge metal forever. Your consumable inventory management will be streamlined. Select your cartridge and with a simple twist onto the torch you’re ready to go.
Benefits of Hypertherm Powermax cartridges
Easy to use
SmartSYNC® torches with the cartridge automatically set the correct amperage and operating mode, eliminating setup errors.
Easy to identify single-piece cartridges are color-coded by process to eliminate parts mix-up and simplify consumable inventory management.
End-of-life detection lets the operator know when it’s time to change the cartridge.
- Simplified operation minimizes downtime, troubleshooting, waste, and training time.
- Upgrading to the Hypertherm cartridge platform is easy for Powermax45 XP/65 /85 /105 systems via a torch adapter for Duramax® torches.
Used cartridge consumables are 85% metal by weight and are easily recycled using normal scrapping processes.
Versatile
Tackle a wide range of jobs with easily interchangeable torch styles and application-specific cartridges for various types of cutting and gouging.
Time-saving torch controls allow the operator to adjust the amperage on the fly and change cartridges and applications without returning to the power supply.
Access cartridge data for performance tracking, analyzing usage patterns when used on SmartSYNC torches.
- Specialty cartridges for gouging, HyAccess, FlushCut™ and FineCut® extends the capabilities of Powermax systems
Torch compatibility
Fully compatible with all SmartSYNC torches, providing automated process set-up and data transfer to the system
Available cartridge reader accessory pairs with Powermax SYNC smartphone app to analyze performance data such as starts, transfers, and arc-on time
Limited functionality with Duramax and Duramax® Lock torches (found on Powermax45 XP/65/85/105)
Requires separate torch adapter (part number 428951)
Does not provide automated process set-up or data transfer
Learn more about the cartridge
Hypertherm cartridges part numbers
Hypertherm cartridges for Powermax systems are manufactured to uphold our high standards for quality and reliability. As part of the manufacturing process, we test-fire each cartridge to ensure proper assembly and function. As a result, there may be burn marks on the tip of the cartridge. This is normal and not a sign of damage.
Drag cutting and FineCut for hand torches
Hypertherm cartridges |
Process |
Cartridge |
105 A |
85 A |
65 A |
45 A |
FineCut® hand cutting |
Drag cartridge:
FineCut cartridge:
Upgrade your current Powermax system
Have a previous generation Powermax? No problem. Owners of our Powermax45 XP and Powermax65/85/105 can enjoy many of the benefits of our revolutionary cartridge consumable platform by simply adding a torch adapter to their current Duramax and Duramax Lock torch. The separate torch adapter will allow you to simplify consumable ordering, inventory, and installation by replacing your current 5-piece consumable stack-up with a Hypertherm cartridge. Learn more.
