HyAccess extended consumables for Powermax systems
Benefits
Patented HyAccess™ consumables extend approximately 76 mm (3″) beyond standard Powermax® consumables to provide the extra reach needed when cutting or gouging in hard to reach or confined spaces. HyAccess’s unique consumable design allows for better visibility and accessibility when working on challenging locations such as corners and channels.
How customers are using HyAccess
Weld preparation
Using Powermax plasma systems and the plasma arc gouge process when preparing parts for welding allows part edges to be beveled to produce a groove for the weld.
Weld preparation
Read more
Using Powermax plasma gouging for metal removal instead of grinding.
Weld and metal removal
Weld repair
Using Powermax plasma gouging for weld repair with HyAccess consumables.
Weld repair
Read more
Compatible Powermax systems
HyAccess consumables are compatible with the following handheld torches and systems:
System Recommended amperage Torch series
Type of consumables
Powermax65/85/105 SYNC® 15–65 A SmartSYNC® Hypertherm cartridges
Powermax45® XP
Powermax65®
Powermax85®
Powermax105®
15–65 A Duramax®
  • Standard consumables
  • Hypertherm cartridges with adapter
Powermax45® XP
15–65 A Duramax Lock
Powermax30® XP
15–65 A Duramax LT Standard consumables
Powermax45®
15–65 A T45v Standard consumables
Powermax30®
15–65 A T30v Standard consumables
Powermax1000, Powermax1250, Powermax1650, Powermax600, Powermax800, Powermax900, MAX42, MAX 43
15–65 A Duramax retrofit Standard consumables
Duramax torches with adapter and cartridge
Upgrade your current Powermax system
Have a previous generation Powermax? No problem. Owners of our Powermax45 XP and Powermax65/85/105 can enjoy many of the benefits of our revolutionary cartridge consumable platform by simply adding a torch adapter to their current Duramax and Duramax Lock torch. The separate torch adapter will allow you to simplify consumable ordering, inventory, and installation by replacing your current 5-piece consumable stack-up with a Hypertherm cartridge. Learn more.
Learn more
