Robotic plasma cutting
Hypertherm Associates’ robotic technologies provide cutting-edge cutting capabilities to support your most complex projects, whether you are cutting structural steel shapes for a building, stadium, or bridge, a dome or pipe for a pressure vessel, or cast trimming.
Overview
Return hundreds of hours to your business
Robotic cutting systems are designed to easily cut various shapes using powerful and intuitive robot programming software. Traditionally, machines were needed to saw, mark, cope, drill, punch, and/or shear complex shapes. However, robotic cutting technology advances have helped customers dramatically increase productivity by eliminating these manual operations — increasing cut speeds, cut quality, and productivity in low-volume runs.
Robotic cutting technology
Many robotic pipe and structural steel plasma cutting applications require greater reach and control into tighter cut spaces that longer torches can't reach. Unlike traditional 2D cutting, robotic movements on complex geometry parts can add additional stress to lead sets from increased bending and flexing.
Hypertherm Associates has developed specific lead sets and torches for its XPR®, HyPerformance®, and Powermax® plasma systems that allow greater flexibility and protection from extreme heat and molten splash. Various structural steel cutting techniques allow cutting from underneath the structural piece or directly on the inside of the web/flange corner of a beam increasing lead proximity and exposure to heat and molten metal blowback.
Robotic cutting software, such as Hypertherm Associates' Robotmaster® offline programming software for robots, has significantly reduced the time it takes to program complex jobs. What used to take days now takes hours, making today's robotic cutting systems incredibly efficient.
Learn about EV cast cutting with plasma robotic cutting systems.
Fought & Company
Before we had the XPR300® system, we struggled to be competitive in pipe and tube and plate cutting.”
Fought & Company
Structural steel
Read more
Coal mining machinery manufacturer
The XPR system's intuitive operation and automatic system monitoring redefine what simple and user-friendly plasma cutting means, and it's easily integrated with robots.
Construction and heavy equipment
Read more
Construction machinery manufacturer
Company gained significantly improved cutting efficiency, with less than 5 minutes for loading, cutting, and unloading with robotic plasma beveling solution.
Read more
A well-known machinery company in Xuzhou, renowned as the "Capital of Chinese Construction Machinery,” is dedicated to the sustainable development of the concrete machinery industry.
Read more
A well-known private construction machinery manufacturing company in Shanghai specializes in designing, developing, and producing fully hydraulic crawler excavators and their spare parts.
Read more
Explore Robotic cutting products
