How Hypertherm’s flush cutting process helped a Brazilian petrochemical plant avoid factory stops
In the past, whenever this Brazilian petrochemical plant had to remove corroded pipes from its reactors, a full 15-day factory shut-down was required. Today, through the use Powermax® plasma and FlushCut™ consumables it is possible to do the job without disrupting production.
Want to learn more? Read more about the flush cutting process here.
