Are updates to my CAM software required for a Phoenix update?
CAM software updates are often necessary, however not in all cases. The more advanced features you use in your CAM software the more likely it is that you will need to update your CAM software.
If using Hypertherm CAM software, check out the software support section or contact CAM Technical Support.
If using other CAM software, please contact your supplier for support.
Go to Software Knowledge Base
