Number 1: Counting down the top five Powermax fault codes: 0-30
We’ve been counting down the most common Hypertherm Powermax fault codes for the past month.
And now, without further ado, we present the Number 1, most frequent error code we get calls about. Are you ready?
Drumroll please…0-30 is the most common fault code seen on the Hypertherm Powermax65, Powermax85, Powermax105, and Powermax125, regardless of whether it is used as a hand held or with a CNC machine. It can mean that there are issues related to your consumables or there could be external factors impacting system operation. To clear this code, start by checking the following first:
Did you change your torch consumables while the power supply was on? If yes, shut down and then power up your power supply.
Do you have the right consumables installed? If no, change the consumables.
Is the swirl ring deformed or damaged? If yes, replace.
Is the electrode surface damaged or pitted? If yes, replace.
Is your air wet or oily? Fix the compressor and/or replace filters.
Is your plasma torch damaged? Test with a spare machine torch known to work and replace torch, if needed.
0-30 fault code Powermax plasma cutter troubleshooting
If you've checked all of the above and the error code still hasn't cleared, it’s time to switch into service mode. We’ve explained how to do this in the Number 2 post, but for those of you who need a reminder, here it is. Look at the front of the system and press the two buttons below the LCD display at the exact same time until you see the screen change. Then look for the letter ‘F’ on the left on the display, fifth-row down from the top. You’ll notice that the fault codes are longer. You’ll either see a 0-30-0 (torch stuck open) or 0-30-1 (torch stuck closed).
Fault code 0-30-0 means the electrode and the nozzle not making electrical contact. Reasons may include:
Wrong consumables
Gas valve is open or leaking
Physical damage to the torch and/or consumables
A deformed swirl ring is stopping electrode movement
An over tightened retaining cap has damaged the swirl ring
Fault code 0-30-1 means the nozzle and electrode are stuck together and cannot create an arc. Possible causes may include:
Low gas pressure
Gas restrictions-check your pressure gauge
Gas leaks caused by a damaged torch lead or regulator
Hose diameter impacting gas or air flow rate
External filters may be constricting the gas flow, verify all flow rates for components feeding the power supply
Gas restrictions
A deformed or damaged swirl ring is stopping electrode movement
Regulator needs to be replaced
To troubleshoot, place the unit in gas test mode and refer to the operators manual for Test 6. Ensure that only the dump valve light is on during the gas test.
If you're still having trouble: more resources
Regardless of the amperage in your power supply, or whether you are using it on as part of CNC plasma table or other automated system, you don’t have to go full DIY mode. Hypertherm Cutting Institute offers a short course with a full video on troubleshooting and resolving a 0-30 fault code.
Hypertherm’s North American Technical Service Team can help. If you’re in the United States or Canada, call (800) 643-9878, or email the team.
If you need a new or replacement part, we recommend reaching out to one of our authorized distributors or service centers. For a list of locations near you, visit our where to buy page.
