Specifications
General
Maximum OCV (U0) 360 VDC
Maximum output current (I2) 400 Amps
Output voltage (U2) 50 – 200 VDC
Duty cycle rating (X) 100% @ 80 kw, 40° C (104° F)
Ambient temperature/Duty cycle Power supplies will operate between -10° C and +40° C (+14° and 104° F)
Power factor (cosφ) 0.98 @ 400 ADC output
Cooling Forced air (Class F)
Insulation Class H
Mild steel cut capacity Dross free
Production pierce
Maximum cutting capacity
38 mm (1-1/2")
50 mm (2")
80 mm (3.2")
Stainless steel cut capacity Production pierce
Maximum pierce**
Severance
45 mm (1-3/4")
75 mm (3")
80 mm (3.2")
Aluminum cut capacity Production pierce
Severance
45 mm (1-3/4")
80 mm (3.2")
Speed
(Mild steel)
Book specification at highest output current
12 mm (1/2")
4430 mm/m
(170 ipm)
Cut angle ISO 9013 range*
2-4
Weldability   Ready to weld
Process gases
by material
(Plasma/shield)
Mild steel
Stainless steel
Aluminum
02/Air, 02/02
Ar/Air
H35/N2, N2/N2, H35-N2/N2, F5/N2
Ar/Air, Ar//N2
H35/N2, Air/Air, H35-N2/N2
Ar/Air, Ar//N2
Process amps
(Cutting)
Not all processes available
for all materials
30-400
** Maximum pierce requires usee of an autogas console and controlled motion process. See technical documentation for details.
Consumables
Please contact an authorized Hypertherm distributor to place your consumables order.
HPR cartridge
HPR cartridge consumablesNew!
Mild steel process Retaining cap Cartridge (10 pk) Water tube Torch body
80 A (standard cutting / bevel cutting)* 420708 420803 420728 420729
130 A (standard cutting / bevel cutting)* 420708 420705 420728 420729
260 A (standard cutting / bevel cutting)* 420708 420715 420728 420729
HPR cartridge kitsNew!
Type Kit p/n Includes p/n Description Quantity
Torch starter kit 528101 420729  Torch body 1
    420728 Water tube 1
    420708 Retaining cap 1
    528107 Kit: O-ring cartridge torch 1
Cartridge 3-pk kits
528102 420803 Kit: Cartridge, 80 A 3
  528103
420705
Kit: Cartridge, 130 A 3
  528104 420715 Kit: Cartridge, 260 A 3
   528105** 420803, 420705, 420715 Kit: Cartridge, multi-amps 3
** Note: 528105 cartridge multi-amps kit contains (1) of each amperage (80 A, 130 A, and 260 A).
HPR400XD standard consumables
HPR400XD torch
HPRXD torch
Mild steel
Shield cap     Shield   Nozzle retaining cap       NozzleSwirl Ring Electrode Water tube 400 amp Torch consumable parts
400 amp consumables - mild steel
Amperage Shield cap Shield Nozzle retaining cap Nozzle Swirl ring Electrode SilverPlus electrode Water tube
30 A 220747 220194 220754 220193 220180 220192 ______ 220340
50 A 220747 220555 220754 220554 220553 220552 ______ 220340
80 A 220747 220189 220756 220188 220179 220187 420566 220340
130 A 220747 220183 220756 220182 220179 220181 220665 220340
200 A 220637 220761 220757 220354 220353 220352 220666 220340
260 A 220637 220764 220760 220439 220436 220435 220668 220340
400 A 220637 220636 220635 220632 220631 220629 420530 220571
80 A bevel 220637 220742 220845 220806 220179 220802 ______ 220700
130 A bevel 220637 220742 220740 220646 220179 220649 ______ 220700
200 A bevel 220637 220658 220845 220659 220353 220662 ______ 220700
260 A bevel 220637 220741 220740 220542 220436 220541 ______ 220571
* 260 A bevel 220637 220897 220896 220898 220436 220899 ______ 220571
400 A bevel 220637 220636 220635 220632 220631 220629 ______ 220571
* Recommended for use if you have excessive slag, or the torch is misfiring, when using standard consumables.
Stainless steel
Shield capShieldNozzle retaining cap Nozzle Swirl Ring Electrode Water tube 400 amp Torch consumable parts
800 amp - stainless steel - above 4″ thick
Amperage Shield cap Shield Nozzle retaining cap Nozzle Swirl ring Electrode Water tube
45 A 220747 220202 220755 220201 220180 220308 220340
60 A HDi 220747 220815 220814 220847 220180 220339 220340
80 A 220747 220338 220755 220337 220179 220339 220340
130 A 220747 220198 220755 (H35)
220756 (N2)
220197 220179 220307 220340
200 A 220637 220762 220758 220343 220342 220307 220340
260 A 220637 220763 220758 220406 220405 220307 220340
400 A 220637 220707 220712 220708 220405 220709 220571
130 A bevel 220637 220738 220739 220656 220179 220606 220571
260 A bevel 220637 220738 220739 220607 220405 220606 220571
400 A bevel 220637 220707 220712 220708 220405 220709 220571
Aluminum
Shield cap ShieldNozzle retaining cap Nozzle Swirl Ring Electrode Water tube 400 amp Torch consumable parts
400 amp - aluminum consumables - above 4″ thick
45 A 220747 220202 220756 220201 220180 220308 220340
220756 (Air)
220197 220179 220307 (H35)
220181 (Air)
220340
200 A 220637 220762 220759 220346 220342 220307 220340
HPR400XD standard consumable starter kits
Designed especially for your HPR400XD system, the Hypertherm consumable kit contains all the necessary consumables and accessories you need to get up-and-cutting. Customers can choose either mild or stainless steel/aluminum consumable starter kits.
Kit type (MS) HPR400XD mild steel starter kit (400 A and below)
Kit part number 228367
Description Kit contains all the necessary consumables and accessories for mild steel cutting at 400 A and below
Kit type (AL/SS) HPR400XD aluminum and stainless steel starter kit (400 A and below)
Kit part number 228368
Description Kit contains all the necessary consumables and accessories for aluminum and stainless steel cutting at 400 A and below
Upgrades
Rotary Tube Pro 3
A pipe nesting software with complete design and cut functionality.
Read more
SilverPlus electrodes
SilverPlusĀ® electrodes last over two times longer than standard copper electrodes  significantly lower operating costs and reducing the number of changeouts.
Read more
Field service bulletins (22)
Showing 22 of 22 documents
Showing of 22 documents
Show all
Technical support
